Help installing residual valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2006, 07:10 AM
when installing resid. valves that have a directional arrow is it correct to have it pointing toward the wheel cyl or the master cyl? have it pointing toward the wheels but not acting right
Old 02-01-2006, 08:26 AM
Hi. Arrow points toward wheel cyl. As far as brake problems go there is a ton of info in the knowledge base.
Moon
Old 02-01-2006, 11:26 AM
Thanks, thought I was right but wanted to be sure before I started back at square one- Thanks again
Old 02-01-2006, 11:41 AM
302 Z28's Avatar
What about it is not acting right?
Vince
Old 02-01-2006, 04:03 PM
feels like it may still have some air in the lines- 1st pump of petal is soft ,second is ok-wait a few minutes and try again and same result- it's a double chamber master w/ 7" booster- sound like air to you??
Worth it to put bigger valves in stock seats??? sizemoremk Engine 3 08-13-2005 12:19 AM
residual pressure valve Blob Suspension - Brakes - Steering 1 12-31-2004 03:45 PM
Unshrouding valves - how much is it worth? Mad Maggot Engine 6 11-17-2004 07:37 PM
Valves GearHead69 Engine 3 10-13-2003 04:51 PM
Residual Pressure Valve?? Dave E Shank Suspension - Brakes - Steering 1 12-27-2002 07:12 PM
