help with kill switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2010, 08:17 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok so I've asked this question before but didn't get the answer I wanted.What Id like to know is what is the easiest way to install a kill switch in my car,something with just a wire&toggle switch.I have an 83 monte carlo thanx
Old 01-18-2010, 09:40 PM
n_keiser_rat's Avatar
its homemade, and its cheap!!!
just cut the coil power wire and make the wires longer to your switch
Old 01-18-2010, 09:51 PM
two cups of tea
Wiki Edits: 2
How do I tell which one that is?I HAVE AN AC DELCO electronic ignition distributor
Old 01-18-2010, 11:23 PM
where is the coil is it on top of the cap or bolted somewhere on the intake or fire wall and a plug wire ran to the center of the cap? either way if you look on the distributer cap if the coil is on the top of the cap, it will be labled on the cap one will say tack and one will say batt cut the batt and run it to your switch. if you have an external coil on some they are labled and one will have + cut that one and run it to your switch, others will have like a pink and some other color cut the pink and run your switch from their
Old 01-19-2010, 12:07 AM
two cups of tea
Wiki Edits: 2
Awesome,Ill try to figure this out&do it sometime this week thanx!
Old 01-24-2010, 09:02 PM
fast68's Avatar
likes chevy trucks & boobies
just toggle the 12v to the distributor BATT terminal
simple.
same as shutting key switch off
Old 01-25-2010, 07:30 PM
If anyone wants a diagram to a kill switch that can act as a theft prevention device, let me know. I don't know how to load pics on here so pm your email address.
I do relay wiring drawings for the fun of it sometimes, I can pretty much come up with anything you can imagine.
You guys probably already had this stuff figured out 20yrs ago though.
Old 01-27-2010, 10:46 PM
no start
83 monte carlo brown wire under steering column neutral safety switch - input to start get it now
kill switch question... cutthroatkid Electrical 2 11-22-2009 01:42 PM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Wiring a kill switch hallamwillis Electrical 17 02-19-2007 05:25 PM
Emergency Kill switch question Mrfixmaster Electrical 14 12-08-2006 05:52 PM
kill switch shineoneforme Electrical 1 02-04-2005 06:06 PM
