Help with lifter making a tapping noise?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2012, 10:55 AM
My son has a 1995 chevy 1500 z71 350 small block. At times the lifter on the driverside will start sticking and start making a noise. I was told I could add some trans-fluid to the oil and it might make the lifter pump back up,or quit sticking. im not sure how much to add or if i should even try it. any advice would be great. thanks.
Old 05-25-2012, 06:03 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Being a 95 its prolly got a flat tappet cam and the lobe is worn, best bet is replace the cam and lifters. with the **** oil we have nowadays to go with our **** gas, you either have to run racing oil, or regular oil with a zinc additive, gone are the days of running regular oil only for flat tappet cams. to do so now is running on borrowed time.
Lifter making noise? cloned1973 Engine 2 04-07-2012 04:22 PM
ok well there this tapping noise while idling chevy302builder18 Engine 3 07-15-2011 11:22 AM
Tapping noise in engine? Bucketwrench Engine 10 11-29-2009 09:37 AM
Tapping noise. Johnx64 Engine 8 06-19-2008 08:56 PM
Higher RPM Tapping Noise 400smb_s10 Engine 5 08-07-2007 02:42 PM
