Help in Making Baffle Inserts for Collectors - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2008, 07:50 PM
I need some help in making baffles for over-the-fender headers on an open frame model A coupe. I would like the units to fit inside the collector and use the collector reducer to hold in place, thers are 2.5" OD. The headers are from Speedway ceramic coated on a sbc 400. Can I use heavy grade stainless steel wool used for cleaning? How about a 3/8' threaded rod with
steel or aluminum discs drilled with holes spaced apart then inserted into collector? Noise level?....anything less than open headers is fine!
Thanks for any suggestions.
Old 08-04-2008, 08:19 PM
SSedan64's Avatar
I've only heard 1 car that had the baffle type inserts and they were much quiter than open headers. They all look to be pretty simple to Fab. Something like these>
http://www.jegs.com/p/Patriot+Exhaus...10002/-1/10265
http://www.jegs.com/p/Car+Chemistry/...10002/-1/10265
http://www.speedwaymotors.com/p/1701...xtensions.html
Old 08-04-2008, 09:45 PM
427v8's Avatar
C6, the C5 of tomorrow
Wiki Edits: 7
I run auger mufflers ( first link) on my 460hp 400 small block.
I use 2 1/2 per side with the center open and with a crossover.
3 was too quiet, Capping the center tube made it sound really weird.
Keith
Mold making questions ChrisMiddleron Body - Exterior 14 10-07-2008 03:03 AM
Making a drag racer mrcare General Rodding Tech 4 01-19-2007 02:55 PM
Making A Fiberglass Console For The First Time nightrain_rod Interior 4 03-07-2006 02:46 PM
Loose Baffle? dion Engine 3 09-14-2002 07:09 PM
