NEW INTERIORS, no disrespect meant toward you at all. Last edited by techinspector1; 08-23-2009 at 09:09 PM. |
You would be totally wasting your time and money to mod the engine for higher revving horsepower. The top speed that you will ever reach can't be much over 50 mph, if you're doing it right, so put the time and money into all the little tricks and such that go into a derby-winning car. You will never see a winning derby car/driver w/a hot rod engine. There's just no point in it. You want something to live under duress- to live when overheated, low on oil pressure, etc.
I think you have a complete mis-understanding the Enduro or cruiser class in dirt track racing. It is not a demo derby at all, although it appears to be because of the skill of many of the drivers and the lack of mods that can be made. The enduro class is an entry level class that can be be done on the cheap. Building a godd hobby stock car can be financially out of reach for many people. A good enduro car can be built well under $1000. I raced my 2001 crown vic for two years in New Mexico and still would be if they did not close down the track. Our average raqce night consisted of one to two heats of 10 laps and then a 20 lap A and B main. If any car was in a bad accident or spun we had the yellow come out just as any other class. We usually had between 30 to 45 cars per night show up. As a class we put more money and fans in the seats than the other class. Due to bad management the track run by the indians was shut down and the equipment sold off. Here is a link to the general rules of the class. http://www.westcoastenduro.org/rules.html
My reference was so that others can zero in on what I believe the original poster was getting at. When you hear the word "derby" thrown into the conversation you immediately think demo derby as opposed to any actual racing.
BSE Racing Engines |
dman16, I don't know if your organization adheres to the rules posted by BugRod or not, but there are a couple in there that you may want to pay attention to...to wit...
"The intent of the engine rule is to keep it stock with no more than 9:1 compression" "compression test not to exceed 180# per cylinder." " Must have a minimum of seventeen (17) inches of manifold vacuum @ 1000 rpm." "NO STROKER MOTORS. Stock intake and exhaust manifolds only." |
www.kitsapdestructionderby.com/ has info for you guys. rules, picture of cars and the track or go to you tube and search kitsap destruction derby. http://www.youtube.com/watch?v=44SnOfmtB_Y thats a link to a good video of what ill be doing. ill maybe do 10 laps at most and run the car for a whole 10 minutes tops per race.
Looks like fun. I'll give you my take on it just from watching the figure 8 video.
From a driveline standpoint, I'd start with the biggest motor I could bolt in the car. As you come around the outside tire and gun it across the middle of the track to the next inside tire, you'll need all the low end torque the motor can muster and that means starting with lots of cubic inches and using a short cam to make max grunt. That's a very short track drag race and I don't see the advantage of a high-winding motor in which you have to use a lot of cam that kills low end torque. I might be thinkin' starting with a 440 and using a cam matched to the static compression ratio (based on the available fuel) that will nose over at around 5000 rpm's and make max torque around 3500-4000. I'd use a 727 auto trans with a 3000-3500 stall converter and a rear gear that would allow max revs at the inside tire on the next corner. Finding out the mph these faster cars are going when getting to the next inside tire will allow you to do some back-figuring and choosing the right gear and tire size. That would be my low-buck approach. If I had some extra money to throw at the car, I'd be thinkin' stroker crank for even more grunt. I see in the rules that you can run 2-wheel brakes. I wouldn't do it. You're gonna need all the braking power you can muster to avoid other cars in the middle of the "X". You can't win if you can't finish. I know very little about circle track setups, but with the little I do know, I'd be setting the front end camber at several degrees negative on each side and maybe extending the upper control attachment point at the spindle up some to improve camber gain on bump. I've seen where these extensions are commercially available. At the end of each heat, I'd be measuring the temperature of the tire tread from one side of the tread to the other. This will tell you where to set the camber and tire pressure. I used to do that when my son was racing go-karts on a road track and we had the car to the point that it would corner like it was on rails. I might be all wet, but that's just my take on it from watching the video. Last edited by techinspector1; 08-24-2009 at 07:37 PM. |
the 400 is the biggest i have to put in the car. so what parts should i put in the motor to make it reliable and strong? i kno this motor and chevy motors have the same firing order could i drop in a crank from a chevy into this mopar for a longer stroke for less rod angle to get side load off the pistons? i have a crank from a big block chevy laying around 3.76 inch stroke out of a 427.
.........No.
. Put a tune-up on the motor and leave it alone, dual exhaust, and 4.56+ gears if you can get someone to do it for you.
| 400 sbc | Devin 427 | Engine | 19 | 06-08-2010 07:17 PM |
| 400 small block chevy | shevyman | Engine | 11 | 01-15-2007 05:52 AM |
| 6" Rods in a 400 | Blazin72 | Engine | 19 | 12-23-2006 09:04 PM |
| Why would you build a 383 small block chevy | 454me | Engine | 15 | 06-19-2005 07:23 PM |
| Small Block 400 | chevyelc81 | Engine | 9 | 06-18-2002 06:10 PM |
