Help Me get my Linkage right! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2009, 10:19 AM
TorkMonster400's Avatar
uninteresting default message
Last journal entry: A couple of pics of the car
Wiki Edits: 4
With all the styles of ways to do my throttle cable and TV cable(700r4). can anyone help pick out the right part for me. I've been looking for one that is inexpensive and will hook up on the side of my carb with return springs and has a spot for the tv cable. I belive I need a tv corrector also. any help would be great. I'm using the new summit carb, they said 4150 parts fit.
do I need this
http://www.summitracing.com/parts/SUM-M08080/
or this
http://www.summitracing.com/parts/SUM-210240/
and one of these?
http://www.summitracing.com/parts/SUM-700202/
Any info will be a help thanks again
Name:	carb linkage side.jpg
ID:	40204   Click image for larger version
Name:	motor carb linkage side.jpg
Old 08-24-2009, 04:31 AM
Wiki Edits: 4
no really I'm amazed some of you didn't jump on a chance to put some parts together
Old 08-24-2009, 06:39 AM
I am sure there are others more experienced then me BUT, you will need the bracket with the square opening to secure the TV cable and you will need the lower part to go on the carb. to get the correct ratio on the cable pull. I used both on my ford f1 1950 with a 700r4 and a 327 motor. almost can see in this picture ED
TH350 Hift Linkage mightycarlo10 Transmission - Rearend 1 03-23-2008 08:36 AM
Progressive Linkage On Blower Carbs Setup? 5-7heaven Engine 6 10-07-2007 11:30 AM
tunnel ram linkage pal Engine 2 03-19-2007 08:34 AM
Firebird and Camaro clutch linkage BanditT/A Transmission - Rearend 1 10-25-2004 10:13 PM
clutch linkage!!? chevyelc81 Transmission - Rearend 11 08-01-2002 07:46 AM
