help me ID these sbc iron heads with 2.02/1.60 valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2010, 08:27 AM
I picked up these heads yesterday from a guy on CL he said they are dart iron 200cc heads 64cc but i cant find any info or real casting numbers. They have 2.02/1.60 valves, perimeter and center bolt hols for valve covers, angle plug, and comparing the intake runners to a LT1 gasket i had laying around the are the same size. i took tons of pictures so hopefully someone will identify these.
Old 12-22-2010, 08:28 AM
Old 12-22-2010, 08:42 AM
Banned
Why do 3 out of 4 guys hack up the port entrance? Its usually the last place that needs enlarging, often needing to be filled in, and they just hack it up and don't even bother to blend it in.
When you rebuild those I would try to clean up that mess and a little bit on the short turn.
As far as identification, I would call up DART and ask them, they should know how to identify any of their heads.
Dart Machinery
353 Oliver Street
Troy, MI 48084
Main Line: 248-362-1188
Main Fax: 248-362-2027
You can also email them here: http://www.dartheads.com/products/contacts/
Old 12-22-2010, 08:46 AM
King of my Man-cave.
Look like World Products heads, Sportsman perhaps.
tom
Old 12-22-2010, 10:49 AM
[QUOTE=ap72]Why do 3 out of 4 guys hack up the port entrance? Its usually the last place that needs enlarging, often needing to be filled in, and they just hack it up and don't even bother to blend it in.
Dart Machinery
353 Oliver Street
Troy, MI 48084
You can also email them here: http://www.dartheads.com/products/contacts/[/
QUOTE]
Hey thanks for their contact info. I am unsure of what you mean by the port entrance? Do u mean where the bolt goes like the surrounding?
Old 12-22-2010, 11:13 AM
ericnova72's Avatar
More for Less Racer
Looks like World Products Sportsman to me also, from a time after World Products split from Dart. Dart hasn't made the Sportsman head in about 10+ years now.
Old 12-22-2010, 11:16 AM
Banned
The area before the pushrod pinch. Depending on a lot of things that area can often be filled in and see a power gain (if done properly), a lot of people make it bigger- usually a mistake.
Old 12-22-2010, 12:46 PM
I have a pretty much stock 350 with a small cam and a single turbo right now with a blow thru setup that's runnin stron... I an buildin a 383 stroker on the side with forged internals so that's what these heads will go on with the single turbo... I'm wonderin if anyone can or know where to get the specs for these I'm sure if they are in fact 200cc runners with some decent porting and polishing these heads will provide enough flow for the 383. Right now I'm at 450-500whp with the current setup and crappy truck heads not vortec.. with the 383 I'm lookin at 650ish whp on 93 octane as long as the heads will flow enough imsure these will handle the power
Old 12-22-2010, 01:30 PM
Banned
If you're going to rework them what they are eally doesn't matter so much, you'll need to get the CSA's right, clean up the short turn and the bowls, cut down the guide, clean up the chamber, get a valve job, and surfacing. It's all going to alter the heads a lot so I wouldn't be too concerned with what they were as cast. As far as volume goes, 200cc's means relatively nothing when you start talking about modifying them and searching for max power. You can have two modified 200cc heads that make nowhere near the same power.
Old 12-22-2010, 01:56 PM
I wasn't looking to rework the whole head just the basic port and polishin smoothin the runners and upgrade the springs with new valve seals.I'm not looking for peak hp from heads since I can always turn the boost up to make up for it I just didn't want a head that will choke my motor
Best valves for Iron Eagles. Peer81 Engine 12 03-17-2010 09:15 AM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Best iron heads? Mike_82 Engine 2 01-30-2006 04:39 PM
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 05:06 PM
best iron heads for sbf Dubz Engine 10 01-14-2004 03:02 PM
