Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help me identify this front end
  #19 (permalink)
Old 06-13-2010, 12:12 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
I could be wrong, but I think those look like the original MII rotors, or maybe Granada 10" rotors with GM calipers. What is the diameter and bolt pattern? Give one of the brake companies a call, there are several different 11" rotors available, some make the track width wider than others.
ECI has some brake kits and they say which ones move the wheels out from the stock location and which ones don't.
http://ecihotrodbrakes.com/mustang_p...nversions.html
Be careful if you start trying to use parts store rotors, pretty much all of the swap rotors that come with the brake kits have mix and match bearings and races to get them to fit the MII spindle...Some are actually less than perfect matches too, but seem to work. (case in point: I once got a set of rotors for a fatman kit, and they sent out a rotor with a bearing race to install that actually lets the rollers hang out the race a little bit)
Later, mikey
BE different....ACT normal.
