Help me lower my '68 Buick!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2002, 12:59 PM
Post Help me lower my '68 Buick!!
I want to lower my stock '68 Buick LeSabre, but so far have been unable to locate short springs or drop spindles. I don't have the money to put in airbags, does anyone know where I could find lowering parts for my Buick?
Thank you, thank you very much
Old 12-11-2002, 04:33 AM
aka Duke of URL
Arrow
Well...
In this case, the easiest thing to do is cut your present springs (with cut-off wheel and a quarter coil at a time) until you get your desired trim height.
Then you need to check your suspension rebound travel to get the proper shocks and to make sure there is no suspension/steering bind. Don't forget to check for bump steer.
Do what you need to for the desired rear trim height and have it PROFESSIONALLY aligned.
Old 12-13-2002, 10:12 PM
Lou's Avatar
Lou Lou is offline
Last journal entry: some more body shots
Post
You could raise the lower ball joint up 2" it takes alittle cut and welding. Or you could make the spring pocket deeper.Again alittle cut and weld action.
Old 12-14-2002, 10:08 AM
Don Meyer's Avatar
Post
Probably the best way is to remove the lower control arm, cut the spring pocked out, weld a round spacer to the pocket & weld the pocket back in. A 3/4" spacer will lower the front 1 1/2", a 1" spacer will lower it 2".......Don
I think this is what Lou is talking about after re-reading his post. You can also do the same to the rear by raising the pocket.
[ December 14, 2002: Message edited by: Don Meyer ]</p>
