help me with my 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2002, 05:20 PM
Post help me with my 350 chevy
hi , ok iam having a problem with my 350 my rocker arms are making a really bad knocking noise on the driver side i tired to adjust them , i got them to get qiute but after 2 weeks later the noise came back. i dont know if the cam went flat,or if it is the lifters , if any one came help plaese.
Old 09-02-2002, 05:28 PM
Talking
[quote]Originally posted by INSANEracing:
<strong>hi , ok iam having a problem with my 350 my rocker arms are making a really bad knocking noise on the driver side i tired to adjust them , i got them to get qiute but after 2 weeks later the noise came back. i dont know if the cam went flat,or if it is the lifters , if any one came help plaese.</strong><hr></blockquote>
If it's a Chevrolet 350.....
The rocker arm studs may be pulling out of the head. It used to happen a lot in the past.
The only cure is to pull the heads and either pin the studs or drill and tap the heads for threaded studs. Both are best left to a compentant machine shop.
Better than a flat cam unless you want a bigger camshaft.
Old 09-03-2002, 01:37 AM
Post
Hello;
Well, your cam could be going flat...but, you maybe have some heavy duty valve springs and the rocker arm studs that are pressed in are coming out. Had the problem on my 64-GTO 389 ... when I decked the block I had screw in rocker studs installed and all was well.
My fix for a little while was to knock them back in with a hammer! Not recommended!
Regards,
VanAgain350
Old 09-03-2002, 05:59 AM
Post
I would check to make sure the nuts are not backing off. Several years ago I had the same problem after some head work. I found if you install the nuts back on the same studs you come out ok but if you put the nuts on different studs they seem to come loose. Try new nuts.
Old 09-03-2002, 05:36 PM
slider in wa's Avatar
Slider in Wa.
Post
I chased this same problem a few years back. I got it corrected with new Nuts. Good luck and let us all know what you find.
Slider in Wa
