Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help me and my G-Body handle better
Old 08-12-2012, 09:56 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Hey Everyone! I have a long list of upgrades to do this winter to my 1986 Olds Cutlass Supreme. My current setup is a vortec headed 355, Howards roller cam 180325-08, 10:1 compression, 2800 stall converter, Th350, ford8.8 rear end, Factory 14x6 Rally Wheels , and factory replacement monte carlo ss supsnesion through out.
For the winter I am planning on putting AC back into it, a 200-4r OD transmission, dual 2.5" exhaust, and hopefully new wheels, tires, and suspension so it doesn't handle like a complete mess...
Right now if your driving down the road and you jog the wheel back and forth there is a huge amount of body roll and it just feels horribly sloppy. I am not into road racing but I would like it to handle much better than it does now. What would you guys suggest?
A lot of people say to start with anti roll bars and wheels. I figured due to the factory 14" wheels I am loosing a lot through the large amount of side wall I have. I really like the design and look of the Olds rally wheels on my car but I believe the largest size the factory made were 15x7 which idk if that will give me enough of an upgrade to make it worth it. Suggestions?
Also since I swapped in the 8.8 the axle tube is bigger in diameter so the rearend sits really high. I would like to drop it down some so I will have to look into some lowering springs.
Also is the factory power steering setup worth upgrading? Leave it alone?
Sorry for the essay here but I just want to give you guys as much information as you will need to help me out as much as you can.
Thanks!
Shane
