Help me and my G-Body handle better - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2012, 08:56 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Hey Everyone! I have a long list of upgrades to do this winter to my 1986 Olds Cutlass Supreme. My current setup is a vortec headed 355, Howards roller cam 180325-08, 10:1 compression, 2800 stall converter, Th350, ford8.8 rear end, Factory 14x6 Rally Wheels , and factory replacement monte carlo ss supsnesion through out.
For the winter I am planning on putting AC back into it, a 200-4r OD transmission, dual 2.5" exhaust, and hopefully new wheels, tires, and suspension so it doesn't handle like a complete mess...
Right now if your driving down the road and you jog the wheel back and forth there is a huge amount of body roll and it just feels horribly sloppy. I am not into road racing but I would like it to handle much better than it does now. What would you guys suggest?
A lot of people say to start with anti roll bars and wheels. I figured due to the factory 14" wheels I am loosing a lot through the large amount of side wall I have. I really like the design and look of the Olds rally wheels on my car but I believe the largest size the factory made were 15x7 which idk if that will give me enough of an upgrade to make it worth it. Suggestions?
Also since I swapped in the 8.8 the axle tube is bigger in diameter so the rearend sits really high. I would like to drop it down some so I will have to look into some lowering springs.
Also is the factory power steering setup worth upgrading? Leave it alone?
Sorry for the essay here but I just want to give you guys as much information as you will need to help me out as much as you can.
Thanks!
Shane
Old 08-12-2012, 02:43 PM
Listen and Learn
Wiki Edits: 7
I figured I will start with these since my current ones are bent from my lack of welding skills
1978-88 GM G-Body Rear Control Arms with Bushings - Speedway Motors, America's Oldest Speed Shop
Also I figured I would get a set of 15x7 Olds rally wheels and maybe some 255/60 tires?
Old 08-15-2012, 02:11 PM
Checkout this guys build he really has went thru alot in his pursuit of happiness >> Project SicMonte
Old 08-19-2012, 03:59 PM
Listen and Learn
Wiki Edits: 7
thanks for the link ill check it out! anyone else have any input or suggestions? Im gonna get a thread going on over at gbodyforum.com but i would still like to hear some other opinions.
200-4r....How much can it handle? Bull_81073 Transmission - Rearend 9 03-29-2008 11:33 AM
Hurst T-handle coupe66 Transmission - Rearend 2 04-01-2007 08:44 AM
How much HP/TQ can an M20 handle? TCAMARO Engine 5 10-26-2004 05:23 AM
how much can the handle? low77ride Transmission - Rearend 6 02-24-2004 12:24 PM
can it handle low77ride Transmission - Rearend 6 11-17-2003 04:05 PM
