those two things are huge contributing factors to what your compression ratio will be, i wouldn't order any parts until you know those things. |
Help Me Out Before I Purchase
Like plaintoast said you need to know the effective head volume or the part# of the pistons that are in the block. If you don't know you can't buy the heads with the correct combustion chamber. The cam and the heads you are going to purchase are great but you need to know which to buy 64cc heads or 76cc heads. If you have flat top pistons which have a 7cc effective head volume the compression will be too high 10.88 with 64cc heads. With the pistons you have in the picture and if the deck of the block has not been milled your compression is about 8.99 now.
Well based on what I can gather I think the pistons are about -13cc. This is sort of an estimate, but I am about to research ways to measure this. I remember someone saying I could use clay and a graduated cylinder to measure. My old man and I have about decided to not pull the motor and just do the top end. The block was rebuilt, god knows why someone put these pistons in it... or maybe back in it.
So the 8.99 compression is with the 64 cc head with these pistons? Well damn... they don't even make this head in with a smaller comb chamber. And the 305 heads that were on this block were supposedly 58cc. I also tried to measure deck height today but wasn't sure how to deal with the "bevel" around the piston. I guess the deck height would be less than the measurement to the bottom of that bevel. I guess I'll try to find a way to measure these pistons and report back. Thanks for the help. |
you'll want to measure from the deck surface to the highest spot on the piston, not real sure what you mean by bevel.
but by my calculation, i actually come up with 8.49:1 with the "64" cc heads. |
You can buy a gasket that is .015 compressed thickness over the stock .041 thickness. Mill the heads or buy heads with smaller combustion chambers. Change the pistons. Usally decking the block is the hot ticket if its already been done you need to figure your compresion ratio. It looks to me like the pistons come right up to the top of the block. United Engine & Machine Co. Incorporated Use that link and actual measurements to figure out the details. Hope this helps. |
the easiest way, if you aren't pulling the lower end apart, would be to use a thinner gasket and angle mill those heads.
Those look like the Cast 13cc 4VR w/Dish Pistons to me.
Silvolite Pistons-CHEVROLET 4.030" Bore X 3.480" Stroke. .025" Deck Ht., .015" Shim Gasket. 64cc Head, 13cc Piston = 9.52:1Cr |
| what was your first new car purchase | garrell.770 | Hotrodders' Lounge | 21 | 01-29-2012 09:06 PM |
| Which waterneck should I purchase? | 7dcrzr | Engine | 4 | 08-21-2007 10:04 PM |
| Need to purchase | flatford39 | Garage - Tools | 6 | 04-23-2006 07:33 PM |
| new tripower purchase! | pcoghlan | Engine | 9 | 03-05-2006 09:17 AM |
| Newest purchase | Kevin45 | Hotrodders' Lounge | 5 | 03-03-2005 09:24 AM |
