help me out guys i'm new - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2008, 09:53 PM
zak zak is offline
I've got an '86 chevy c10 w/ a 305 and i dont have enough torque to make me happy, any suggestions on how to add torque without spending too much cash?
Old 09-24-2008, 10:32 PM
powerrodsmike's Avatar
Wiki Edits: 161
You need to post this in the engine forum, I'll see about getting an art forum mod to move it up there..
Later, mikey
BE different....ACT normal.
Old 09-25-2008, 12:59 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Sell the 305 and the money you got, get a 350, then you can upgrade the 350. You got 45cid to start with. Even better yet get a 400sbc. Then you are talking torque. Well over 400ft pound of pulling power. Because a 305 will not produce to torque you are looking.
Old 09-25-2008, 02:33 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
The 305 is already pretty maxed out in the torque area. You're limited by size. Doing a search on the internet usually turns up a few free 350s, some that run. At worst, spend $400 on a good running one that you can test and drop it in.
$400 and a weekend engine swap and you've just added 100 lb-ft
Old 09-25-2008, 02:53 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
c'mon guys, he wants to be happy. Why not a big block 454 out of a late model truck.
Old 09-25-2008, 03:07 PM
lg1969's Avatar
The reason is, If try to install a big block you have too modified the exhaust system, a bigger radiator, different motor mounts. A 350 or 400 sbc will bolt right on same place a 305 was in. Save a lot of $$$$
Old 09-28-2008, 02:21 PM
FIRST = Bet your cam is running 4* retarded due to timing chain wear. Install a 3 keyway timing chain, and time the cam 4* advanced. That will give you 8* more cam advance. $ 50
Second = 4 tube headers, 1 1/2 inch diameter.
Collector extensions to a total length of 24 inches,
8" long cone reducers to 2 1/4" true dual exhaust,
H pipe,
Magnaflow mufflers,
at least 15" turndowns, or tailpipes.
$ 500
Third = Distributor ignition advance recurving, using full manifold vacuum to the vacuum advance can. $ 50
You could do this second, but it probably needs to be redone after the exhaust.
Fourth = more rear end gear $ 300 or if you can find a good junkyard rear
OR slight stall converter. $ 600 or luck into a used one at a swap meet.
Fifth = mess with the engine, etc. $$$$$$$$$$
Can Get My Ignition Switch Out Guys ! SCHOONER General Rodding Tech 1 08-20-2008 08:11 PM
OK GUYS! last chance for the sticker run before they go on ebay! chevyluvnpuppy Hotrodders' Lounge 10 06-30-2008 07:23 PM
What Would You Guys Like To Chop For This Month ?? Only Racing Hot Rod Art 6 03-31-2008 12:04 PM
Guys Who Know Me, It's been a while, let me bring you up to speed, new car pics. Ghetto Jet Hotrodders' Lounge 24 11-07-2007 11:27 PM
when ya guys get board mustangman1968 Hotrodders' Lounge 16 04-03-2004 08:44 PM
