The one problem I see is that with 0 deck and flat tops you're probably going to end up with too much compression for a blower.
BSE Racing Engines |
On The stock motor the stock piston is .025" below deck and a .015" head gasket is used. This results in a .040" detonation supressing piston/deck net quench clearance. In order to use a .039" elpro gasket and maintain that .040" net quench clearance in the final assembly you need to cut approx .025" off the block.(measure yours twice, cut once) the intake manifold will end up very close to where it belongs. If slight distributor shimming is nessessary, thats what you want to do. Won't be a big deal. Its all in the details. All part of making those $ affordable$ but not optimum L2256F (fits your budget) pistons, live a long life. You'll want the piston ring end gaps on the loose side. Other than that and proper carb and timing tuning there is not a lot of undue stress on the piston on this combo. But.. if you can find the $$'s in your budget for a set of JE pistons, go for it. Start getting too crazy with the nitrous either way and all bets are off....LOL A little will go a long way. i think you'll be more than happy with this motor without needing nitrous. Maybe some of the pro machinists can chin in here with some cool but affordable block, oiling system and crank tweeks and mods to help. Last edited by F-BIRD'88; 12-30-2007 at 11:31 PM. |
Just to throw my hat in the ring:
I don't like stock cranks for applications with 500+ horsepower. A 350 has to be pretty well tuned for that much power and with a blower the chances that everything will hold up and stay in spec is seriously reduced. This is just my opinion but there are some rotating kits out there that will make you feel alot better about the strength of your bottom end. If your budget will not support it then you got to do what you got to do, but the piece of mind you will get with a set of rods and a crank that is made to handle that much power is almost priceless. Say your distributor comes loose and advances the spark to a point that you have some detonation,with the compression above 9:1 and a blower the first time you put your foot in it you can say good bye to stock rods and then the crank. It all comes down to what you are going to do with the motor as well. You mentioned race applications and if you are going to turn it above 6500 RPM the pistons will be moving like 3500+ feet per minute and then turn around and come back down that will put tremendous stress on the rods. If it is too advanced it would increase stress quite a bit (like throwing a two pound hammer at 40 MPH and trying to stop it by hitting it with an aluminum bat) I am kind of a what if guy but I have yet to genade a motor, because I build them 30%-50% stronger than they are capable of running. This also means that you know your motor will handle HP upgrades or nitrous. |
The 2256 is just a forged copy of the stock piston. To keep cost down why not use the TRW-2442P which is now sold under the Sealed Power/ Speed Pro name. It is made for blowers/turbo's and will do the job with the little blower you are going to use.
| How to tell if a shop is good or reliable | MARTINSR | Hotrodders' Lounge | 48 | 12-31-2007 08:42 PM |
| 71 350 machine work | gothrod87 | Engine | 1 | 04-29-2007 06:52 AM |
| Finding a good machine shop? | jtybt | Engine | 5 | 02-09-2006 12:09 PM |
| "a little over" turns into $4500 over for paint job | bullheimer | Body - Exterior | 128 | 02-06-2006 08:57 AM |
| machine shop bias... | onebadmerc | Engine | 30 | 02-06-2005 03:12 PM |
