Help me with part names - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2005, 11:26 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
I'm not all-together sure what to call some of these components on my 74 camaro suspension. Can anyone put the proper names to the parts? This will help me when it's time to order parts.
Old 10-16-2005, 12:06 AM
ronb's Avatar
the easy way to do this and for other reasons as well is for you to go to your local auto supply and get yourself a haynes manual for that year and type of vehicle!
Old 10-16-2005, 12:37 AM
montea's Avatar
tryn to learn
yes a haynes manual will tell you all the parts, lots of info.
a- upper a-arm
b- sway bar
c-intermediate rod
d-steering knuckle
e- inner tierod
f- lower a-arm
g- steering knuckle, outer tierod is connected there.
h- brake sheild?? i dont know what you are pointing at there???
i- sway bar end link
Old 10-16-2005, 04:51 AM
garretthes's Avatar
Haynes Manual is a good idea. I think I have a dozen of those things from all the cars I've owned over the years.....
350 or 383 Stroker? my350camaro84 Engine 19 07-30-2012 07:44 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Tip of the day #13 MARTINSR Body - Exterior 6 12-24-2005 03:09 PM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 12:21 PM
Part 2--Metalshaping/Panel Replacement '34 Chrysler fender Randy Ferguson Body - Exterior 1 06-03-2004 07:27 PM
