Help Me Pick A Cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2005, 01:56 PM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Help Me Pick A Cam
I putting a new 350 together to put in my ride (1989 Silverado). I have bought quite a few pieces and when funds allow I'll buy the rest. I'd like to ask the pros here as most of the people on the truck forums haven't a clue, here is what I'm using
Brand new GM Performance 4 bolt block (350)
Sealed Power 10.5:1 Forged pistons
Sealed Power rings
ARP Mains studs
7 quart oil pan
Summit high volume oil pump
Pete Jackson gear drive (Quiet)
Streetmaster rods (steel)
Clevite 77 bearings
0.10 under iron crank
6 7/8" Streetdampr
Dart aluminum heads (2.05/1.60) 64cc (need to order)
Comp Cams solid lift cam .555" lift (need to order)
Edelbrock Scorpion single plane intake
Holley 750 double pumper
MSD distributor
MSD 6AL box
MSD multi step retard
MSD blast 3 coil
MSD 2 step
NOS Dual stage cheater
This engine will be coupled to an
API turbo 400 tranny
API 10" 4000 stall
TCI Transbrake
Rear end is a factory 10 bolt with Richmond 4.56 gears and a posi
My last 350 had 12:1 compression, iron bowtie heads (2.02/1.60) Reed .555 solid cam and one one stage of nitrous ran 11.8@115mph
What do you think of this combo and any times?
I'm thinking on either a hydrolic cam or solid lift cam
Hydrolic cam specs
Gross Valve Lift 0.525 0.525
Duration At 0.006 Tappet Lift 305 305
Valve Timing At 0.006
Open Close
Intake 43 82
Exhaust 83 42
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 253 253
Lobe Lift 0.35 0.35
Lobe Separation 110
Or this solid lift cam
Gross Valve Lift 0.555 0.555
Duration At 0.015 Tappet Lift 306 306
Valve Timing At 0.015
Open Close
Intake 47 79
Exhaust 87 39
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 260 260
Lobe Lift 0.37 0.37
Lobe Separation 110
Old 11-16-2005, 02:08 PM
CC
This looks like a really strong (meaning potent) setup. I assume the goal is to spend a lot of time at the track. But Charlie, are you really sure you want to run all this through a CI crankshaft?? Not meaning to seem negative, but even cranks like a SCAT (cast of steel vs. CI) are limited by manufacturers recommendations to 500HP or so. I've gotta believe you'll blow right through 500 HP. Regarding the cam, for an application like this, I really can't help. Looking for this much power, I think I'd be looking at roller profiles.
Old 11-16-2005, 02:11 PM
The Big Money
I only plan to spend a little time at the track maybe 5% I'd really like to lift the front wheels off the graound by a couple of inchess
HELP cam, intake, carb 64 nova Engine 9 07-12-2005 11:39 PM
flattened cam 383vette Engine 7 05-04-2004 11:02 AM
Help Me Pic A Cam? Grant209 Engine 5 12-22-2003 06:05 PM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 12:29 PM
cam selection chevyelc81 Engine 9 09-17-2002 07:41 AM
