Help Me Pls , Carb?????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2007, 11:33 AM
i HAVE A 79 EL CAMINO, REPLACED THE ENGINE A COUPLE YRS AGO, I'm not sure what yr the new engine is. I believe it's a 350. Heres the problem, beforeit got fixed i gave the old carb away. the mechanic was able to use the carb off the newer engine, even though it's computerized and my veh is not. I can't pass emission's for ****. I've found holly II at checker for around $180, do i match the carb up to my engine, or to my veh yr, make and model?? I beleive the holly part i'm looking at is 647160. would this the be the correct carb for my veh?? Emissions said running too rich, some of the computerized sensors are not connected on the carb thats in the engine now.
Old 02-20-2007, 11:39 AM
DeathRattle's Avatar
Some Punk Kid
What aspect of the emissions test are you failing?
You may just to to do some tuning to lean out the carb as much as possible. You may run a little hotter, but just so you pass emissions testing.
I looked up on rockauto's website which is usually all OEM listings and they show a few carbs. 2 and 4 barrel rochesters.
They are very expensive. around 300. They have a 50-60 core charge.
Old 02-26-2007, 10:14 PM
See if you can find another OEM carb like your old one, from a similar vehicle or from one with a similar engine. Or maybe you could buy your old one back.
Old 02-26-2007, 11:17 PM
fast68's Avatar
likes chevy trucks & boobies
that EST/ESC carb will run very rich if its not connected to an ECM
lots of fuel in the exhaust will occur
you need to find a non computer signal controlled carb
a good shape non computer Q jet from the mid to late 70s is plenty lean enough from factory to pass emissions easily
make sure you hvae a VERy breathable air filter
if not then it will be more rich of mixture because it will starve for air and therefore the intake charge will be more fuel rich of a mixture
and if it doesnt pass the first time then you can lean it more by putting in a hair larger primary rods or hair smaller primary jets
very easy to swap these in a Q jet, very common carb parts are all over for them i have crates of Q jets and parts in the attic and other places
good luck
backfire thru carb airraptor Engine 11 06-12-2009 02:30 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 03:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
