help me understand fiberglass/smc repair and products
Hey all, I did a basic search and got some answers but not all. I just need someone to explain the difference between epoxy resin SMC resin and polester resin and when to use the three and why. I have done some fiberglass repair in the past but am wondering how correct I was. Also the difference between mat and cloth would be appreciated. Thank you
ok so the smc has to be repaird with an epoxy resin only i presume? what would happen if a polyester resin would be used?
You can use smc repair on fiberglass but not fiberglass repair on smc. The smc repair actually works better on fiberglass .
I always use the matt myself I don't care for the cloth. Never had a real problem with strength.
I fix alot of semi hoods and most of that stuff is smc. The repair procedure is the same just have different resins. All the stuff we use is from Evercoat and they use a cream hardner just like what you would use with body filler. The cost is $100 a gallon compared to the polyster stuff at $50. The fiberglass mat works much better than the cloth.
The problem with the cloth is it can leave patterns that come thru to the paint, even when buried under primer. The Mat has no patterns and is more like the glass sprayed into a mould that most stuff is made from.
Brian |
any repairs to a corvette should be done with epoxy resin even the older ones. i use matt and i also use cloth. i prefer the cloth for many things . cloth is suppose to be covered with vail cloth for hiding.
| Fiberglass Repair | CJ Runner | Body - Exterior | 2 | 08-11-2010 07:45 AM |
| fiberglass repair need help | donkeydawn11 | Body - Exterior | 3 | 03-02-2010 06:53 PM |
| unlimited products fiberglass | dorksrock | Body - Exterior | 1 | 12-05-2005 06:47 PM |
| FIberglass repair | mitmaks | Body - Exterior | 2 | 04-16-2003 07:45 PM |
| Fiberglass Repair | ronszepher | Body - Exterior | 4 | 03-07-2002 05:21 AM |
