help me understand ring gap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2006, 12:08 AM
njbloodline666's Avatar
I Love VTec
there are certain things i dont understand, like why is running too tight of a ring gap bad, why do nitrous motors require a wider gap. etc...any info to help me understand this will be cool
thanks
Old 05-19-2006, 04:24 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Just like anything else in an engine, rings expand when they get hotter. You have to set a gap when its cold so that they don't butt together when hot. If they do, they'll wedge in the bore and scratch, or they'll gar the piston... or both.
Nitrous engines see much higher peak temperatures in the chamber, which means you need to run a little more gap since the rings might see higher temps.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
Gap problems fender to door when front fascia installed Ripped Body - Exterior 25 03-19-2006 07:15 PM
Piston ring end gap Oldphart Engine 2 01-06-2006 02:33 PM
rpoper spark gap for 350 mikeweyman Engine 4 11-30-2003 06:06 AM
Ring End Gap bpd411 Engine 3 02-26-2003 09:19 AM
