Help me wire my ELECTRIC FANS! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2008, 06:17 PM
DarknessSpawned's Avatar
God Of Lightning
Since Im trying to finish up wiring... And went through the power window
relaywiring in the end to conclude I should not use the relay... Id like
to double check my fan wiring diagram...
Does this look alright... What would you perhaps do differently
if you dont agreewith my diagram?
Old 12-07-2008, 06:56 PM
Last journal entry: More on the Cobra Engine
You seem to have taken quite well to the electrical thing...
The two 30 amp fuses are over kill, but that's fine, I would like to see them come from the fuse panel and not by way of an add on fuse at the battery. Why have two fans if your going to control them both together. I would use a staggered approach and have one fan, say the larger of the two, come on at a set temp, say somewhere in the 175-185� range. The other should come on only as a back-up to the first, which you could control with another temp sensor or thru a relay set-up, or Spal controller. The control wiring, which in this case would be minimal, should be fuse protected and say in the 10 AMP range, I would also install a convenient switch that would allow me to manually intervene and control the fans when I want. This arrangment works well when you want to make sure the fans are working, and allows the manual operation should the Temp sensor fail.
I have several fans on my project:
Radiator fan, 1-16" turbo fan
Engine Oil Cooler, 1-8" B&M fan
Transmission Oil Cooler, 1-8" B&M fan
Inter-cooler Water Cooler, 1-8" B&M Fan
I use 4-temp sensors and 2-Spal fan controllers and a remote water pump to make the system function. The fan controllers are a great way to slow down the fans so they don't make to much noise, and allow them to come in at pre-set stages, with only the one sensor as in your case.
This water resistant controller is programmable, and will read almost all OEM and After-market sensors on the market.
-Programmable to activate at any temperature
-Factory programmed to 160� Low, 200� High
-Variable speed for reduced fan noise
-Uses OEM or optional SPAL Temp Sensor
-Waterproof extruded aluminum construction
-LED indicators for High, Low, and A/C
Old 12-07-2008, 07:33 PM
Countilaw's Avatar
Cox Custom Cars
If you are running a air conditioner, I would wire one fan to come on when the a/c was turned on.
Old 12-07-2008, 08:00 PM
God Of Lightning
Funny you should say that, I actually wass going to do that at first.
But Couldnt decide how to make themanual over ride switch work.
And also since v8s10's are always having cooling issues, I decided
to skip 2 temp switches because it would only save me a little bit
of time between fan cycles and I want to make sure it STAYS cool
so Im not that worried about the 2 fans running at the same time...
But I would like to insert the manual over ride switch.
I already have a 3 prong blue light switch..
How do ya do it.
Old 12-07-2008, 08:54 PM
75gmck25's Avatar
Based on your diagram, it looks like the temp switch provides a ground for both relays when the temperature goes above 185. To have a manual override, all you have to do is add a switch that manually grounds the circuit.
Run a wire (16-18 gauge) from the 85 terminals up to the dash switch, and ground the other side of the switch. When the switch is on, it provides ground and turns the fans on manually.
Bruce
Old 12-07-2008, 09:52 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
Take a look at how Alan did his, he use 2 relays for each fan &
http://www.alanhorvath.com/54chevy/mad_electrical_2.php
Old 12-08-2008, 01:03 AM
God Of Lightning
Bruce
How about one of these for each fan.......
http://store.summitracing.com/partde...5&autoview=sku
And can it be grounded anywhere? Best place?
I wouldnt mind lighted switches would look nicer
but would need power for the light and might not work well.
EDIT: I'll add a diagram....
Old 12-08-2008, 06:20 PM
God Of Lightning
No objections... Sweet Ill go with this setup then.
Old 12-11-2008, 09:43 AM
The manual override switch is really convenient. My thermal switch seems to vary at what temp it activates the fans. Sometimes the engine temp gets above the set point and the fans don't immediately come on, so I can turn them on manually if I want.
Also, I drilled an extra hole in my dash panel and added a small amber light right under the temp gauge. Wired the light into the fan circuit so it comes on when the fans come on. I can't always hear the fans, so the light tells me whether they have come on or not.
By the way, I am running a 15 inch Cooling Components fan on the backside of the radiator, and a 12 inch Spal fan on the front of the AC cooler mounted in front of the radiator. Each is powered thru relays but controlled by one variable temp switch. 25 amp fuse on the big fan, 15 amp fuse on the small fan.
John
Cruise Control Compatibility with LED's? cboy Electrical 44 10-01-2010 12:08 PM
Electric fans not fanning when switched on lumberjacknooj Electrical 6 06-01-2007 02:13 AM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 04:33 PM
Electric cooling fans. "Pusher" or "Puller"? NASCAR314 Engine 4 11-09-2002 04:06 AM
Electric Cooling Fans (CFM's) 41willys Engine 1 10-06-2002 05:10 AM
