Help me wire my horn on my 54 chevy! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2009, 12:13 AM
I used the ez wiring kit to re wire my ride. I bought an after market 1949-50 butterfly wheel. Now I need a way to wire the horn button on the wheel. I took of the original hub Assembly. from the column. So if any one has an idea feel free to help me out. if you have pictures or drawing that will help me too. I need a way to make the horn button work, thank you.
Old 02-22-2009, 06:36 PM
327 / 350 hp's Avatar
Horny 54 Chevy
Can"t be that difficult, got any pics.. Should be 1 wire, ground.. Any pics.327/350hp
Old 02-22-2009, 07:31 PM
1947 Chevy Coupe
This is not exactly your truck but the same wiring. You supply constant hot to the relay, both the coil and one side of the contacts, then the other side of the coil grounds through the steering column when you press the horn button. The other side of the relay contacts feed the horn itself.
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
need advice on 54 chevy 54HellAir General Rodding Tech 12 07-19-2006 02:42 PM
54 chevy Mrwood Transmission - Rearend 1 07-11-2006 06:29 PM
'54 Chevy grille effienut Hotrodding Basics 4 03-22-2006 09:09 AM
Headlights for my 54 Chevy Pickup horvath Electrical 11 01-10-2005 07:15 AM
