Help me wire my POWER WINDOWS! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2008, 11:19 PM
DarknessSpawned's Avatar
God Of Lightning
In my 88 s10.
Okay Ive been cleaning up the wiring, and I'm re-doing the power windows. It didnt have power windows from factory so a I got some switches/wires out of an older caprice or something(a full size box body car).... Not sure exactly what it was now. I had them all ghetto wired up before now I'm doing it right and using a relay in there and running the switches to the console. But My uncle and I cannot figure out the wiring for the whole thing using a standard bosch style relay (Thought the relay would help with the straining windows, Also bought a new motor for the driver side door).. But if the relay isnt useable in this application Id still like to discover the best possible way to wire them using my unfinished diagram on down below.
The way it was before (functional):
RH side:
Pink was Positive power
Pink/Green & Pink/Purple together into negative.
Blue & Brown went to motor
LH side:
Blue/whiteStripe & Tan together into negative
So that being said, Ive done a diagram, All colors and wires are EXACT[U].
Can somebody help me out with this we cant find a schematic
that clears it up or anything so Here is the base for it all..... Black octagons
are what the switches plug into, I did them just like if you were looking at them:
The first time we wired them up it was lots of trial and error, and burned wires, I want to avoid all that this time!! Thanks in advance
Old 12-01-2008, 11:28 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
30 should be a main battery lead. 86 should be the switched power. Double check your wiring with this link.
http://www.6066gmcguy.org/BoschRelay.htm
Old 12-02-2008, 12:30 AM
powerrodsmike's Avatar
Wiki Edits: 161
You have the switch wiring right, the relay is not necessary, but if you want to wire it in, I'll add a little to what carsavvycook said. (check your link Stephen.. )
#30 is B+ from battery, preferably fused
#87 goes to your pink wires to power up your switches.
#86 is from any accessory terminal on your fuse panel
or ignition switch, hot in run or accessory position
#88 goes to ground
#87A not used, This is the normally closed side of the relay.
The relay might not help with dragging windows, wiring it direct to the battery is the only chance that it could. Use a minimum 12 g wire to go from the battery to the relay. Ground the windows as close to the battery as possible if you want to avoid voltage drops from crappy ground straps, etc.
Hope this helps,
Mikey
BE different....ACT normal.
Old 12-02-2008, 12:48 AM
My 2 cents worth
Wiki Edits: 3
#88 goes to ground
Hope this helps,
Mikey
I'll edit it. OK?
Old 12-02-2008, 12:52 AM
My 2 cents worth
Wiki Edits: 3
It's fixed Mike .................................................. .........................
It must have been this part of me
Old 12-02-2008, 01:58 AM
Wiki Edits: 161
There ya are...drawn by my inner child with a filthy mouse for a crayon.
Later, mikey
Old 12-02-2008, 04:58 PM
God Of Lightning
Later, mikey
Hey Mikey..... Its bootiful mang
Thank you so much!!!!!!!!!!!!!!!!!!!!!!!!
I dont know why it was so confusing
to me but you cleared it up very nicely.
Old 12-07-2008, 04:37 AM
God Of Lightning
Little PROBLEM.......
Okay I wired it up like this basically........
Except I dont have a battery so to test the windows I hooked up a battery charger to the ground of the relay, and the switchs, then Hooked the positive clamp to the wire before the fuse as if it was the (+) battery terminal... And got no response.
The meter read 12 volts at the relay on prong #30 but was not going
through the relay to the windows, No other prong was reading anything.
So Then I just hooked the positive clamp of the charger to the positive window pink wires directly and bypassed the fuse/relay and the windows worked fine.
Could the fact I wired #86 to the hot terminal on the firewall instead
of the fuse panel? I liked it like that so I could roll them up or down
without turning the truck on, But like I said its not going through the relay and I tried2 different relays, Same thing...... Must be something with the wiring everything seems like it SHOULD work!!!!??
So Either I need to modify the wiring, or what changes do I need to make
to drop the relay and wire without it if we cant figure it out. Hoping its something simple.
Anybody have any ideas?
Oh and would old switch wires contribute to slower up/down time?
Old 12-07-2008, 06:50 AM
My 2 cents worth
Wiki Edits: 3
Just using a battery charger is not a good test. A battery charger supplies voltage, and very little AMPs to the circuit you are trying to check. You will need to have a battery installed to supply the AMPs needed by the window motor.
You also need to have the body grounded to the frame, and the battery, for a accurate test.
It is a large amperage draw that blows fuses, or burns wires, not the voltage it's self.
Old 12-07-2008, 09:41 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Saving this for posterity...i may need it someday..
Sam
Old 12-07-2008, 10:17 AM
Wiki Edits: 161
The way you are using that relay, (all the time energized and the power circuit hot), makes it a totally unneccessary part..
If you wanted to use it as designed, the relay would be a remote switch to control the power (large load) to the window system with the ignition switch (lets a small load through ignition switch to control the larger load.).
But the way you have it wired, all it is is an overly complex connector. As I said before, having that power relay in the circuit won't make the windows work better at all.
If you really want to use it, try hooking post 80 to the common ground for the window control circuit...
You can use a battery charger to test the circuits, but the chargers output is not good for the window motors.
I use a charger and a battery to test those systems when I install them.
Later, mikey
Old 12-07-2008, 05:37 PM
God Of Lightning
Later, mikey
So ground 80 where the switchess ground?
If so I did that and it didnt work. WE tried to make
sure all grounds were there to make it theoretically just like
being hooked to the battery... I wont be gettin a battery for another
couple of weeks at least. I mean the relay looks cool and is
mounted all nice and neat but it aint workin and I dont see why it wouldnt.
Maybe put the pink wires straight into the fused link, to the battery
and use the relay for something else perhaps? Just want the windows
to work properly and not worry about half a$$ing
Old 12-07-2008, 05:56 PM
Wiki Edits: 161
Are you powering up terminal 86 as well? That is what powers up the relay coil to close the contacts at 30 and 87.
I noticed you did not say that you had your charger hooked to terminal 86, only that you had it hooked to the hot accessory terminal in the fusebox...but with no battery, that terminal is dead.
Ground your terminal 80 to the same ground as the switches.
That relay will fail sooner if it is left on all the time like you are wanting to do by hooking it to the always hot terminal in the fuse box. Not only that, but it will be a constant drain on your battery. IIRC those relays draw .2 amps, that's enough to drain a battery in a few weeks.
If it were me, I'd leave the relay out, and just hook to the battery if I wanted to operate the windows with the key off.
That relay is gaining you absolutely nothing, the way you are using it.
Later, mikey
Old 12-07-2008, 06:15 PM
Wiki Edits: 161
BTW, your relay's terminal numbers don't look like any of the relays I have.
check the pic..
You must have 12 volts going from 85 to 86 (your 80) in order to have current flow from 30 to 87.
86 gets grounded. (I'm not sure it matters if it is reversed, with 85 being ground and 86 getting bat+)
Later, mikey
Old 12-07-2008, 06:31 PM
Wiki Edits: 161
Just checked one of the relays I have, it draws .17 amps and does not matter which way current flows through the coil.
Whne you energize 80 and 86 (or 85 86 on my relays), you should hear a click...that is when the contacts between 30 and 87 close.
80 and 86 are seperate circuits from 30, 87 and 87a, and need to be powered seperately.
Later, Mikey
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Wacky Power Windows airman_turtle Electrical 12 08-16-2006 07:18 PM
Upgrade to power windows Moon Interior 4 06-09-2006 05:54 AM
power windows wrangler Electrical 7 03-02-2006 02:21 AM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 05:22 PM
