help mopar/engine guys. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2008, 07:57 PM
Hey Guys, merry xmas...its me the guy with the roadrunner again....ok well the plugs are still oily....NOW she wont stay running for more than 2 minutes and she stalls out....what the heck...tempermental @#$%^&* anyways im wondering if the plugs are so oiled uo that it cant fire but thats weird because it should still keep running...crappy but should continue running...after the 3rd or 4th stall she wont event fire up, almost like its flodded which again makes no sense..something with the plugs ..gotta be! Im gonna check stuff this week..any ideas?
mike
Old 12-24-2008, 03:51 AM
Last journal entry: 50 Ply wagon
Are the plugs oily or are they gas covered? If they are oliy , you should have lots of blue smoke coming out the exhaust, if the exhaust is black and you smell gas, then the motor is running way to rich. You need to check out the carb and see how its jetted. Sounds like the jets are way too big. I would also check the spark to each plug to see how hot each one is.
Old 12-24-2008, 07:54 AM
Wiki Edits: 49
I agree with sunsetdart. It sounds like a carb problem and its dumping way too much gas in the engine. Had that happen once a long time ago on a big block Vette after it sat for a month or so in the Florida heat without being started. One of the internal gaskets in the carb dried out and cracked and it just flooded the engine with gas. It acted exactly the same way as your Roadrunner. Rebuilt the carb and that cured the problem.
Old 12-24-2008, 08:10 AM
life is a temporary assignment
Look down the carb after you have ran it.(NOT RUNNING)Look to see if the carb is dripping into the motor after it has ran.If so,like Centerline has told you rebuild your carb..
Can Get My Ignition Switch Out Guys ! SCHOONER General Rodding Tech 1 08-20-2008 08:11 PM
What Would You Guys Like To Chop For This Month ?? Only Racing Hot Rod Art 6 03-31-2008 12:04 PM
Guys Who Know Me, It's been a while, let me bring you up to speed, new car pics. Ghetto Jet Hotrodders' Lounge 24 11-07-2007 11:27 PM
when ya guys get board mustangman1968 Hotrodders' Lounge 16 04-03-2004 08:44 PM
Ever use these guys? 79 Malibu327 Engine 5 03-24-2004 08:32 AM
