help with motor mounts - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-19-2011, 01:57 AM
ericnova72's Avatar
More for Less Racer
If you have a power steering box currently, a switch to a manual box will gain you quite a bit of room, it is smaller.
  #17 (permalink)
Old 10-19-2011, 06:13 AM
TroyBoy's Avatar
Psychomotors
I tried the block huggers one time. Won't work . The outlet points directly at your pitman arn and is too close to it . I already have the manual box on mine and it will give you a lil extra room if you don't already have one.
  #18 (permalink)
Old 10-25-2011, 06:37 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
i decided on a rack and pinion conversion its just overall a better choice in the end instead of spending the money on a different box to try and sqeeze it in just wanna eliminate it and all the clunky linkage and simplify and make room with a better steering system
MOTOR MOUNTS (Engine Mounts) PackMule General Rodding Tech 2 08-28-2009 09:52 AM
Motor Mounts 65Stanger Engine 3 04-10-2006 01:15 PM
motor mounts racur96 Engine 1 01-21-2004 10:30 PM
Motor Mounts? LivinProof Engine 2 02-25-2003 07:58 PM
MOTOR MOUNTS NEOAPACHE Engine 3 02-21-2003 06:05 PM
