help with my 1991 305 convertible rs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2005, 02:41 PM
holy crap
i bought the car for $250 if that tells you anything about the condition
i need help with my engine.............it doesnt run by itself, yet..........it knocks but doesnt smoke...........it runs REALLY smooth but knocks.......i need a low budget way to hotrod it and rebuild the engine.........while boosting SOME performance for under $3,500
i need a pro's help
thanks for all input
Old 06-27-2005, 02:47 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
We need more info on the way it runs.What do you mean by not running on it's own,do you have to feed fuel into it to keep it running? If it has a knock,and you got for 2 bills,then a rebuild is probably on the menu for today. Drain the oil,and check for particles that may flow out,also cut open your oil filter if you can,check for metal shavings in it.
Old 06-27-2005, 02:58 PM
spinn's Avatar
a nice muscle car needs low end and a slight stall. like a 1900-2200 stall. a GM HEI ignition unit. a 600 holley vac sec(used very cheap like $25). a sum-1103 cam. or spring for the XE268,springs ,and build 9.5:1 for that combo. use a performer or RPM DP intake. add glasspacks or cheapo turbo's dual exhaust, it will be a fun car.
you can stay under a 3K bugdet and lay tons of rubber!
vortec heads from summit prepared with springs are $650. everytime i see that in the catalog i stop. one time im gonna bite!
i screwed the dog here! i didnt even register that this a 1991 camaro! i have responded to a number of these posts. please pardon the error. disregaurd this post, unless your building something carburated.
Old 06-27-2005, 07:14 PM
yeah umm were having to bottle feed it gas into the throttle body
its uhh in need of a complete reto
but what that spinny guy said sounds about right
i MAY go with that
but i thought about boring and stroking it
Old 06-27-2005, 07:15 PM
i MAY go with that
but since its a 305 im unsure
Old 06-28-2005, 01:38 PM
spinn's Avatar
sorry for any confusion i may have caused. half the time im reading at work and am doing 2-3 things at once. moving the mouse with a cheezeburger in the same hand. that is why to me spelling aint important.
what is your fuel psi?
what is the timming at?
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
dirt track 305 groomer Engine 12 04-20-2008 03:46 AM
1991 Firebird: Conversion from 305 to 350 Chevy21 Engine 6 03-22-2005 01:28 AM
91 rs tbi 305 to 350 carbed tat2 Engine 2 05-15-2004 07:46 PM
Where is my 305 from?? Is it a ligit Chev Engine frankthetank Engine 2 10-25-2003 11:49 PM
