Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help my 383
Thread: help my 383
Old 06-18-2012, 04:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by OMARS67
bk2life-- im consuming oil. wet side pipes but not very much smoke at all. spark plugs arenot foul with oil.
jester---i figured the tester was bad. wanted to see if anyone had that same issue.
Try changing the schrader valve in the gauge, just like in a tire valve stem, same tool same part.
Block the carb wide open for the test- do NOT forget to return it before starting!
