-   -   help my 383 (http://www.hotrodders.com/forum/help-my-383-a-220631.html)
OMARS67 06-17-2012 09:02 AM
help my 383
did a compression test on my 383. engine at 200deg. all plugs out. when i turn the key the gauge is jumpy and moves really guick. i can see it goes up to 160 ish but its to fast to deterimine a real number. needle goes up rapidly then down. it doesnt build pressure or slowy move and stay at a reading. its like this on all cylinders. any comments?? doing a leak down tomorrow.
bk2life 06-17-2012 10:04 AM
need more info.
why are you doing a compression check? whats wrong with it?
painted jester 06-17-2012 10:12 AM
Sounds like the valve in the tester is leaking back! It should hold pressure on each piston stroke till you manually release it!
Jester
Greg T 06-17-2012 12:54 PM
Stop lugging the motor to 1k RPM! Drop a gear and run second or change the rear end gears.
OMARS67 06-17-2012 08:39 PM
bk2life-- im consuming oil. wet side pipes but not very much smoke at all. spark plugs arenot foul with oil.
jester---i figured the tester was bad. wanted to see if anyone had that same issue.
Greg T 06-17-2012 09:11 PM
Sorry. Wrong topic!
cobalt327 06-18-2012 04:27 AM
Try changing the schrader valve in the gauge, just like in a tire valve stem, same tool same part. ;)
Block the carb wide open for the test- do NOT forget to return it before starting! :pain:
painted jester 06-18-2012 09:49 AM
Originally Posted by Greg T
Sorry. Wrong topic!
LOL :D I read it 3 times LOL I was really confused :D LOL
Chris :thumbup:
