help my 383 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2012, 09:02 AM
help my 383
did a compression test on my 383. engine at 200deg. all plugs out. when i turn the key the gauge is jumpy and moves really guick. i can see it goes up to 160 ish but its to fast to deterimine a real number. needle goes up rapidly then down. it doesnt build pressure or slowy move and stay at a reading. its like this on all cylinders. any comments?? doing a leak down tomorrow.
Old 06-17-2012, 10:04 AM
need more info.
why are you doing a compression check? whats wrong with it?
Old 06-17-2012, 10:12 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Sounds like the valve in the tester is leaking back! It should hold pressure on each piston stroke till you manually release it!
Jester
Old 06-17-2012, 12:54 PM
Greg T's Avatar
www.krusinklassics.net
Stop lugging the motor to 1k RPM! Drop a gear and run second or change the rear end gears.
Old 06-17-2012, 08:39 PM
bk2life-- im consuming oil. wet side pipes but not very much smoke at all. spark plugs arenot foul with oil.
jester---i figured the tester was bad. wanted to see if anyone had that same issue.
Old 06-17-2012, 09:11 PM
Greg T's Avatar
Sorry. Wrong topic!
Old 06-18-2012, 04:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Try changing the schrader valve in the gauge, just like in a tire valve stem, same tool same part.
Block the carb wide open for the test- do NOT forget to return it before starting!
Old 06-18-2012, 09:49 AM
Originally Posted by Greg T
Sorry. Wrong topic!
LOL I read it 3 times LOL I was really confused LOL
Chris
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 07:27 AM
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
NA 383 or 177 WEIND 383-Vote bigalow Engine 5 11-16-2011 04:44 AM
383 Stoker vs 383 Chrysler Jag Daddy Engine 100 08-14-2008 11:48 AM
5.7 or 6.0 in a 383 280zxWith305 Engine 16 05-04-2008 09:32 AM
