help with my air set up. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2011, 10:35 PM
So i am having trouble with my air set up. First here are the specs. I have a 2.5 horse power 25 gallon compressor. I dont spray cars just small parts. So my issue is the reading i am getting on my gauges. Here is my compressor.
Uploaded with ImageShack.us
Old 01-13-2011, 10:37 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
oh, do tell
Old 01-13-2011, 10:38 PM
the gauge reads 110 on the gauge on the air filter.
Old 01-13-2011, 10:39 PM
& matts38chev
so whats the trouble?
Old 01-13-2011, 10:40 PM
the gauge on the air regulator on my gun reads 105 psi.
Old 01-13-2011, 10:42 PM
with the gauge fully open and a full pull i only get 29 psi.
Old 01-13-2011, 10:43 PM
& matts38chev
what does the gauge at the filter say when you pull the trigger?
Old 01-13-2011, 10:45 PM
i attached another air regulator and i get 103 on this gauge.
Old 01-13-2011, 10:47 PM
on this one with the knob fully open i only get 27 psi.
Old 01-13-2011, 10:48 PM
let me check give me a min.
Old 01-13-2011, 11:04 PM
reads 90 psi
Old 01-13-2011, 11:35 PM
if you are only spraying small parts youll be fine. I use a flg-3 for basecoats and have sprayed clear with them. I typically run it at 23psi for bases and 28 for clears.
Old 01-13-2011, 11:43 PM
So is my gauge on the gun bad. ? Why is it that I can't get the gauge higher theN 30 psi.
Old 01-14-2011, 12:11 AM
001mustang's Avatar
Restrictions upstream of gauge (regulator, small line, long line, water, debris, etc.) or compressor can't keep up.
Set regulator when air is flowing not when air is dead headed.
Old 01-14-2011, 12:18 AM
I have a 25 ft 3/8 hose with high flow fittings. So this means I won't be a le to use my sata nr2000 to spray a fender or even a door?
