Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with my astro masking station??
Old 01-10-2011, 01:45 PM
cjperotti cjperotti is offline
Yeah, the instructions suck. I don’t have that particular model. I’ve got the tree model. The only difference is you need to remove the arm when loading fresh paper.
First thing you need to know is don’t over tighten the black ends screws as the plastic is of cheap quality and will break. Every new purchaser breaks at least one or two when first assembling and have to wait for replacement parts. Frustration and disappointment is everybody’s first experience with these things.
The end where you’re going use tape just use one of the black ends without a washer. I know they sent one for you to use there. Don’t do it. When the roll gets down that far you’ll discover the tape won’t stick to the car as well as wants to stick to that washer making it difficult to pull the paper through. Additionally, the screw needs to be snugged opposite where the tape and paper meet or you’re going to find out the tape has a better adhesion when it hits it than the washer if you’re not adhering to my advice.
The other end, seeing how now have an extra washer, install washer, then spring, washer followed by black end with screw. Do not compress spring. Just make sure it everything is a snug fit before snugging screw. If you try to compress spring then tighten screw to hold you run a high risk of having to over tighten the screw breaking a second end cap for not adhering to my advice. Thus, compounding your frustration and disappointment further.
Eventually you’ll become accustomed to your new tool with fragile as tissue paper parts, that eventually you’ll be less frustrated and disappointed with it. Although never entirely.
