Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help with my boat please
Old 06-07-2007, 05:48 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
Originally Posted by jrm123180
If it were valves out of adjustment (which is what I am hoping it is) would I hear it or not ness?
If they are too tight then the valve is not seating all the way. No you probably would not hear it. If the valve was too loose it would tick, but probably would run better than you describe. Run the leak down test, it will point you in the right direction.
