Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help with my boat please
Old 06-07-2007, 09:33 AM
boatbob2 boatbob2 is offline
boatbob2
merc overheating
hi,in the merc manifold,there is a riser with a replacable insert.if rust is around this insert (tube) the engine will overheat.also sounds like a valve,piston or headgasket problem,also you may have to re-pitch the prop,too much prop will not allow the engine to rev.
