help.....my car wont run in gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2011, 07:15 PM
i have a 57 ford custom 300....with a 272 y block.....i have a tri power set up and only running on center carb.........blocked all holes and new vac hoses.....i can get it to idle great but as soon as i put it into gear it either stalls........or runs really rough....an anyone help?.....its an offenhauser intake with holley 94s on it...thank you
Old 02-03-2011, 07:18 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, You need to post this in the engine section not everyone checks the "INTRO" section.
You will get more responses there.
Cole
Old 02-04-2011, 08:52 AM
machinist & fabricator
we ran into this problem with my neighbors 63 falcon wagon... she idles perfect, revvs perfect, soon as you drop it into gear, it dies.... the culprit = a fubar'd torque converter
Old 02-04-2011, 09:01 AM
Sounds Like your Intake Manifold is either leaking at the intake ports or base plate of carb is loose (got a vacumn leak somewhere), If the intake has a egr valve port it is either open or leaking etc, Engine loses more vacumn than carb can produce, also check your firing order on the plug wirs something is causing it to run rough, a vacumn guage installed will tell the story, if PCV Valve port is open without a hose/PCV Valve on it ; it will die also the vacumn line for the brake power booster same problem if you have power brakes on it. davidd.goff@yahoo.com
Old 02-04-2011, 09:56 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
A 272 Y-block Offenhauser intake with a EGR port...hmmm.
Old 02-04-2011, 10:36 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What's your timing set at? An engine can sound like it's running great when there is no load on it with out of whack ignition timing and carb tuning but it can run very poorly and have no power once it's placed under load (in gear).
Old 02-05-2011, 04:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You have to set the dwell first, THEN the timing if using points. Did you set the timing w/the vacuum advance disconnected and plugged?
Put a shift kit in and now wont go into gear? nova327 Transmission - Rearend 4 08-13-2010 03:30 PM
700 r4 wont move in any gear gman398 Transmission - Rearend 21 08-23-2009 09:58 AM
4l60e First Gear Wont Shift chevy71z Introduce Yourself 5 08-11-2008 10:58 AM
my c-4 transmission wont go into gear 85stangboy Transmission - Rearend 9 02-27-2005 10:47 AM
HELP PLEASE,tranny wont go into gear..... Rubberman2003 Transmission - Rearend 6 06-08-2003 12:02 PM
