help with my eng # - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2012, 09:21 PM
Last journal entry: change of mind on blower
help with my eng #
hi i have tried over 1 hour to do this my self but i am so so now i am asking for help my eng # c72132982 then samped over it in larger # is v1108tyy dose this make any since to any one all i know it is a 350 4 bolt main but would like to know more about it thanks
Old 10-18-2012, 09:32 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
TYY suffix is a 350 of 1975 vintage found in most trucks. Came with a 4bbl carb and made 165hp stock.
The Following User Says Thank You to Valkyrie5.7 For This Useful Post:
mike lost in cars (10-18-2012)
Old 10-18-2012, 10:23 PM
thank you do you think it can handle 600 hp i got it used it was in a 34 hot rod used for shows only the guy i got it from said it was built about 20 years ago kept it as a 350 and put a 671 blower and never had it tested so my ? is should i leave it as a 350 or will that block handle 383 kit with under hood roots type blower
Old 10-18-2012, 10:24 PM
help with my engine #
V= Flint, 11= November, 08= day of month, TYY 1975, 350, Conv cab, L LS9, 165HP, 4 Barrel Carburetor, C-10- 2500
The Following User Says Thank You to cdminter59 For This Useful Post:
Old 10-18-2012, 10:27 PM
If you have doubts about the condition of the block have it sonic tested. The machine shop will let you know if it is good.
Old 10-18-2012, 10:28 PM
Wiki Edits: 15
+1. Time to take it down to the machine shop and see what you've got.
noise in eng sclev Engine 0 09-17-2012 05:47 PM
4.3 Marine Eng To A 350 Chev Eng DAN CASPER Engine 2 07-19-2010 07:56 PM
eng. #3857655 chronamyd Engine 1 08-24-2009 01:37 AM
5.0 86 eng to a 74 c-4 FEDDO Transmission - Rearend 4 03-08-2005 10:03 PM
pontiac eng 19firebird72 Engine 3 11-23-2003 07:36 PM
