help with my speakers - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2004, 02:15 PM
wrestlingclub142's Avatar
Red face help with my speakers
hey i have a 93 dodge Dakota and i have 2 12" subs in the back that are 700 watts and a 10"sub that i want to put under the seat and thats 800 watts. i have a CD player that pushes 175 watts and a amp that pushes 500 watts and the speakers sound like crap. so can anyone please help me with the speaker problem. plus help me with putting the speaker under the seat. thank you alot
Old 12-05-2004, 05:10 PM
53fordguy's Avatar
Junkyard Kustoms
Last journal entry: update after a long time
Hookin it up
It all depends on how you have it hooked up, if your wiring job is crappy the sound will reflect on it. how do you have it hooked up are wires running near the computer or sparkplugs? are your speakers stock/blown? i need more info to help you...
53 fords rule!
Old 12-05-2004, 05:33 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
What are the specs on your woofers? Brand and Model would be helpful.
Old 12-05-2004, 06:54 PM
More rust
And the amp brands and models would help too... A good amp costs about a dollar a watt. But I can already tell, you're just startin' out? Your CD player won't make 175W if its struck by lightning. Maybe 20-40 if its a really good one. You also need to run the proper crossover frequencys, if you run high freqs to a sub it sounds like distortion and it'll eventually fry them.
Old 12-06-2004, 06:35 AM
you can go to about any place that deals with car audio and they will be able to give u a filter that u can attatch to you imput wires before your amp and ground it and it will take all the engine noise out of your highs. I had this proble with mine and that took care of it parts is about 20 bucks got mine from best buy
also you would prolly be better off with not even useing your other 10 with 2 12's the sound would not be as nice, two different speakers dont just play at the same freqeuncy
Old 12-06-2004, 06:50 AM
more info
i fixed the sound problem i bridged them and charged my battery. but how do i put a speaker under the seat .
Old 12-06-2004, 11:18 AM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
If your putting a sub under the seat just measure to build a box, take the seat out build a box out of 3/4 mdf and put the sub under the seat. I would only put a sub under a seat and not midrange or tweeters. A sub is non directional and doesn't matter where its at in your truck (a cars a little different.)
Old 12-06-2004, 05:03 PM
ok
but what should i build a box out of. plus how should i mount the speaker should i screw the speaker on a board that enclose's the speaker completely or what .
Old 12-06-2004, 05:26 PM
S10Fan's Avatar
Garage Filler
It would be helpful to know the brand and model of the woofer. The box may need to be ported or sealed, and the woofer will have size requirements. Enclosures should be built from MDF. MDF can be found at any Home Depot.
Old 12-06-2004, 06:19 PM
the kind of speaker
its a sony Xplod model # XS-L1037 and it says to use 3/4 wood.
Old 12-06-2004, 06:41 PM
S10Fan's Avatar
Garage Filler
Re: the kind of speaker
I couldn't find any specs for that woofer. I'd try a Sony retailer for specs. If you're still unable to get the specs, I'd build a box with 1 cubic foot of air space and make sure it' s sealed. Cut a hole in the top for the woofer and screw it in. Build the box with MDF (medium density fiberboard), glue and screw it together. Be sure to add a connection for the speaker wires. If you're using 2 12's I'd forget the 10" , but to each his own.
Old 12-06-2004, 06:46 PM
yea but
i will need to cut my seat because the sub won't even go under the seat so should i still cut the hole in the top because arn't u going to be sitting on the speaker, and won't it break it.
Old 12-06-2004, 06:50 PM
More rust
Unless you intend on running another sub amp, forget about it...
Firstly 3 speakers is gonna make some goofy impedence unless they are designed to be used in multiples of 3. Too low and you've found the best way to destroy an amp.
Secondly, unless you up the power, just adding another speaker using the same amount of power won't get you a noticable volume increase. Decibel gain is logritmic, with a given amount of power you have to add twice as many drivers as you had before, ie 1 to 2, 2 to 4, 4 to 8. 4 speakers with 500 watts RMS total will play 3dB louder than 2 speakers with 500W RMS.
The sub would need a box to completely enclose it, only junky free-air type can do without.
Old 12-06-2004, 06:59 PM
S10Fan's Avatar
Garage Filler
Re: yea but
Personally I'd get rid of the 12's and use a single 10. A good friend of mine just won several awards at the sound finals in Louisville. He rates my system as "2 thumbs up" and we both are using a single 10" woofer in small cab pickups. My other speakers are Image Dynamics Mini Horns, and Image 5 1/4 mids. Two Xtant amps provide power with Audio Control processors and a Clarion CD player.
Check this out..............
http://www.diysubwoofers.org/sld/
Old 12-06-2004, 07:58 PM
ok
so do i make a box with a cut in it so the speaker can be seen or do i screw the speaker inside the box. what would be better to be under the seat because if anyone sits in the middle of my seat they will be sitting on the speaker
