Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help need firing order
Old 09-20-2010, 08:37 PM
cliff tate cliff tate is offline
5ltr fireing order
Originally Posted by latech
The H O 5.0 litre used the 351 w firing order 1-3-7-2-6-5-4-8
thanks for the help.Ipurchased a ho 5ltr cor built it up and set the fireing order as you stated(roller cam ) would not run well several dead cyle. so went threw valve and piston position,found mine had early 15 fireing order .wonder when the change cam in. cliff
