Help need firing order - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2002, 04:35 PM
Unhappy Help need firing order
I am putting a "92" Ford 302 5.0 ltr. engine on a 4X4 chasis with a "62" Chevy body. I need the firing order for this engine. I can't find it anywhere!!!!! Help please!
Old 09-17-2002, 05:11 PM
BigBlockBabe's Avatar
Missing You
Post
Firing order for the 302 is
1 5 4 2 6 3 7 8
Old 09-18-2002, 06:09 AM
Post
AAAY Babe, how"d you get my secret *
Old 09-20-2010, 07:38 PM
302 fireing order
what is the fireing order for rollercam engines. i had read the roller mustang 5ltr wher different,but have a early 5ltr that is def 15. cliff
Old 09-20-2010, 08:12 PM
techinspector1's Avatar
Wiki Edits: 326
Here is a neat little site for answering the question of firing order and rotor rotation....
http://www.boxwrench.net/specs_index.htm
Old 09-20-2010, 08:27 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
The H O 5.0 litre used the 351 w firing order 1-3-7-2-6-5-4-8
Old 09-20-2010, 08:37 PM
5ltr fireing order
thanks for the help.Ipurchased a ho 5ltr cor built it up and set the fireing order as you stated(roller cam ) would not run well several dead cyle. so went threw valve and piston position,found mine had early 15 fireing order .wonder when the change cam in. cliff
