help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2005, 07:27 PM
help needed
All right.I hope Im in the right spot? I like to do things differtly,so I got this bright idea.I got an 84 chevy 4x4.One day I decided to take it apart,and put my 85 lincoln body on the chevy fram.Well its done.Ive got it pretty much bottened up except the wireing for the ignition.The way I did it Iused the fuse block from the chevy.So If anyone can help me figure out the ignition wireing it will be greatly appreciated.Thank you
Old 07-16-2005, 03:16 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
yep you landed on the right runway....
let me start by saying
WELCOME TO HR.COM
this is a bit of a poser cause the chevy and fords are a little different in the starter category where the ford has a external solenoid.
i just wonder if the ford ignition switch will handle the load of the starter one way to find out for sure .
it should be very similar but to be on the safe side compare schematics for both if you cant get to a public library i heard AUTO ZONE now has online schematics.
good luck
its possible someone else here has been there done that i'm just speculating
sr66
"SlowRide66"
"Illegitimis non carborundum"
help needed savman1 Engine 4 06-15-2006 10:58 PM
Sealer Needed or Not? Early B's Body - Exterior 9 05-25-2005 02:21 PM
Amount of back pressure needed zipfactor Engine 6 04-21-2005 07:38 AM
what size rim, slick width and backspacing are needed? sb72elcamino350 Transmission - Rearend 3 06-22-2004 04:16 AM
1993 THUNDERBIRD HELP NEEDED ! roberto555 Engine 1 09-09-2002 08:58 PM
