Help needed for ID'ing rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2006, 03:18 PM
HI folks,
I have done a lot of reading on this site to ID a 10 bolt under the 72 sbc Vega my son and I tinker with. This is a new area to us and we are learning so I ask for ya'lls patience here. When I bought the car all the guy could tell me was that he knew the rearend was not stock, and thought it came from a 79 Monza. I can see where somebody cut off old brackets, leaving metal on the passenger side axle tube. Anyway, the stampings on the front of the axles are basically unreadable. The casting #'s on the bottom of the casing is as follows:
GM N
559957
J029
Some other facts:
-The measurement of the cover is 10.8 wide and (approx) 9 5/16" tall.
-There are pronounced pairs of ears on each side, half-moon shaped, both at top and bottom of the casing, they are difficult to see in the pictures.
-The car hooks both tires on accelleration, and the rearend tends to pop on slower, tighter turns.
-The guy told me the gearing is 4:56, I tend to go with that because it runs about 2400 rpm at around 40 with a 25" tire.
I will include photos...
Is this a 7.5/7.625 or a 8.5?
Do the 7.5" have "ears on both top and bottom? It appears in ID photos that the 8.5 does...
We are hoping this turns out to be the 8.5!!!
Any information ya'll could glean from the photos and descriptions will be most appreciated!
jmbjs
Happy New Year!
ID:	17322   Click image for larger version
ID:	17323   Click image for larger version
Old 12-31-2006, 05:24 PM
Looking at the photo showing the front view, the casting appears to have a pad where a torque arm may have bolted? Is that correct? If so, that would lend credibility to the assertion that it's of Monza origin. They were, I think, 7.5" units.
Bob
Old 12-31-2006, 05:58 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
This link talks about how to differentiate between 7.5, 7.625, and 8.5 models.
HTH,
Don
Old 01-01-2007, 06:22 AM
idahotower's Avatar
Know just enough 2B DANGEROUS!
Well.....
It's obviously a 10 bolt rear. The most reliable way to determine the ratio and size is to pop the cover off, read the stampings on the edge of the ring gear, and count the teeth. You could also go a step further and pull an axle to check the spline count and length, just so you have better info to go on for a comparison. The pictures show the car on stands... this is the best time to perform this (where you can get at it).
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 10:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
olds rearend info needed hammerhead Transmission - Rearend 5 10-23-2005 11:53 PM
rearend info needed ricks032003 Transmission - Rearend 3 12-07-2004 09:15 PM
