When you buy a timing chain cover gasket kit it should come with a new front oil pan seal as well. Just note what style seal it is when you take it apart. There are thick and thin seals. The difference will be obvious.
Scrape as much of the gasket off as you can being careful to not let the pieces fall into the front of the oil pan. Another thing is that you're going to have to do is loosen more oil pan bolts than just the front two unless you plan on bending the front of the pan which will not only ruin the pan but lessen your chances of getting a good seal. Once you've scraped as much gasket as you can wipe both surfaces with a rag that's been sprayed with brake cleaner to get rid of any excess oil that remains. Use a very thin coat of RTV on both sides of the gasket. Wipe it thin with your finger. On the rubber oil pan seal put RTV just on the ends where the gasket will hit the block and at the points where the corners of the oil pan are not all the way around where it sits in the timing cover.
BSE Racing Engines |
Hello thanks for your help I only have rtv silicone for my front seal not a rubber seal with silicone at the ends. I will have a lot of scraping to do. I was a little weary on using the rubber end type seal cauuse I have heard they are prone to leak really easy but I am willing to try it and see how it does. I do believe its a thick front type seal cause the pan I have is for 1980-85 style block and it takes a thick seal. I hope things work out but when I go to lower my pan just a little I am worried about damaging my side pan gaskets. They where composite type gasket with indian head tacky stuff on it to hold it in place. Well thank you for your help it will help me a lot. Thanks Eric
gasket
The rubber oil pan gasket is fine to use with cone on the corners but no one uses the rubber end seals on the intake manifold any more. Silicone only will do the trick. Leave the timing cover bolts loose and install the dampner. Fit he seal to the dampner and tighten the bolts.
Clint |
Not trying to rain on your parade but trying to loosen and lower the pan just enough to get the timing cover on, especially since you mention the pan rail gaskets were glued on, is most likely not going to work too well. You will have to loosen ALL the pan bolts and pry it down about 1/2".
There are ways to sneek in the timing cover with the pan inplace but it's not for first timers and fails more often than not. As far as leaving the timing cover loose to fit the balancer, IF the two aligning pins are in the block for the cover, it makes no difference whether it's loose or tight, it ain't moving! |
I only use right stuff on all my engine work. I tried other silicones and adhesives but have failed. Right Stuff is the only thing I use now. You will instantly know the difference when you start to use it.
| fuel pump and timing cover question | 49fordp/u | Engine | 7 | 02-07-2008 08:15 PM |
| Gear Drive to Timing Cover Clearance | Double_v23 | Engine | 5 | 01-11-2008 11:08 AM |
| Gear Drive to Timing Cover Clearance | Double_v23 | Engine | 7 | 01-10-2008 07:12 AM |
| Roller Cam Install - Cam Button & Timing Cover Help | leejoy | Engine | 10 | 12-01-2007 04:28 PM |
| timing cover to pump clearance | club327 | Engine | 3 | 11-09-2003 12:52 AM |
