Help needed rewiring a rewiring on a 70' Charger
While on powertour I went through 2 alternators and 1 battery, still having trouble figuring out whats up with the car. It's a 1970 Dodge Charger R/T, 440ci, ralleye pkg.
Just had a painless wiring harness installed by a shop, but now its nothing but a pain.
After the second alternator in two days I was getting frustrated and started tracing the harness looking for problems. I started pulling the looming off and found several things that concerned me. All the connectors from the old harness were wired into the painless harness by twisting them together and putting heatshrink on them for insulation. No electrical tape anywhere. ***? Why not just crimp on new connectors to the painless harness? Is this normal, I would think not? I found where the heatshrink had split on one of the alternator field wires and grounded out to the alternator chassis. I also found the distributor wiring barely connected. I fixed both of those. Does it matter if the field wires get reversed?
The shop also relocated the battery to the trunk. There is no ground strap connected from the battery to the chassis. The first ground the battery gets is at the end of a 20' 2 gauge cable run from the trunk to the block. Is this normal?
All the gauges, except for the ammeter, quit working the day we left. However the dash lights would intermittently, dimly, come on and we could find no blown fuses.
I guess my questions are 1. What, if anything, is ok with what I considered problems? 2. Could the bare field wires shorting out cook the alternator and are the field wires fused? 3. Does anyone know where to get original or reproduction factory harness plugs? 4. The last alternator we put on was a 76 amp alternator from o'reileys, the original was a 40 amp. Can the factory harness handle this increase in amperage?
Got lots of pics from the tour at myspace.com/dasouthwon
Thanks for the help. Miss you Doc
Reason: additional question
