Help needed with this switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2012, 10:00 PM
I hoping someone has better late night logic than i do. This toggle SPST switch in on my dash to activate the interior under the dash light and a dome light. It has a LED in the toggle that glows when the switch is on. An issue is, that like a lot of dome lights,I guess, the switch is on the negative lead (like a horn). I'd rather not re-wire the whole thing-especially since the dome light wires are under the headliner and I don't know exactly where under the dash they emerge.
As you'll note in the drawings, I can activate the lights, or the toggle, but not both which is what I want to do. Help is appreciated, as always.
Name:	Domelight wire 1.JPG
Old 08-19-2012, 11:18 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hmmm ... *scratches head*
How would this be wired in a "normal" (B+) circuit?
Would the center terminal be wired to ground provide a ground for the light?
If so ... would you wire the center terminal to B+ ???
(use a low amp fuse) LOL
Old 08-20-2012, 05:00 AM
EOD Guy's Avatar
What is the pin out on the switch? Looks like if you hooked the light lead to the L/H pole and the Ground to the R/H pole the ind works......did you try hooking the center pole to the L/H pole and the R/H pole to ground?
Old 08-20-2012, 07:38 AM
Nope-woke up and thought of this about the same time you posted-telepathy? Sure hope not!
Old 08-20-2012, 10:33 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
In your sketch #3 where the indicator LED works (lights) the switch must be in the open position. Voltage is present (through the filaments of the dome lights) on the dome light side of the switch only when the switch is open. When the switch is closed the voltage goes to 0 (ground) on the entire switch.
The LED will require a hot feed from the dome light circuit and the ground side connected to the dome light side of the switch with diode to block backfeed to the LED when the switch is open.
When the switch is closed (to ground) the LED and the dome lights should work.
Due to the design of the switch this may not be possible due permanent internal connections.
I would do a test mock-up of the circuit before installing it.
Post the internal connections of the switch for other possible answers.
vicrod
Old 08-22-2012, 09:48 PM
Thanks,guys. In the end, I made the dome light hot all the time(it's got internal on/off switches) and re-made the under dash light to be a "normal" negative ground/hot through the switch feed so the toggles will work.
Old 08-23-2012, 04:57 AM
EOD Guy's Avatar
Good to hear you got it sorted out.
Trans brake switch showing small voltage, is switch bad? pdmracing Transmission - Rearend 1 09-26-2011 08:50 PM
57 nomad kill switch help needed garinhash Electrical 1 03-14-2007 03:47 AM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 07:04 PM
door switch and brake switch 49dream Electrical 5 02-11-2005 11:58 PM
DIY Shiftlight/ RPM Switch/ RPM Window Switch Junorr Electrical 2 09-07-2004 08:18 PM
