Help needed on timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2013, 10:52 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I am hoping if someone can guide me on this ignition setup I am running. It is HEI on a SBC. Cam is 230 @ .050" and .490" lift on 9.9:1 CR on Vortec heads. Aside from the carb being way too lean, the truck is running great. The ignition is as follows:
initial timing: 26
total timing: 35 (all in by 2,500 RPM)
no vacuum advance
Also I have "medium" springs in the HEI now, but they hold off advance from happening until 2,000 RPM's.
It is a manual trans and 3.73 posi. I think the truck is 3,800-4,000 lbs.
Old 07-10-2013, 12:59 AM
can't do anything with the timing until you fix that lean condition.
Old 07-10-2013, 01:04 AM
vinniekq2's Avatar
are you getting any popping in the carb? Is the lean all the time or just under accelleration?
timing advanced!! is it needed djohnson308 Engine 23 04-28-2013 06:19 AM
Timing advise and help needed STUDE55DOG Engine 12 10-31-2011 10:04 PM
Help needed with new timing cover. eric32 Engine 8 06-09-2008 11:02 AM
92 Dodge 2.5 timing info needed TooMany2count Engine 1 08-14-2006 01:57 PM
Determining Total Timing Needed zipfactor Engine 16 02-25-2006 09:20 AM
