Help needed for trailing arm application
I have little knowledge when it comes to the the right trailing arm set up for my Chevelle (notice I did not say "the best").
Let me explain what I do with the car and the current set up so you guys can offer your option for what would be the most appropriate set up.
For the most part, I show the car at most of the local and regional car shows, so anything I do, I want it to look great. When it comes to driving, the car gets driven around town on the weekends, but almost never see's any highway miles. The motor is a strong BBC with a 350 Turbo and a 12 bolt rear end. I am running ET Radials on the back as well.
The current trailing arms are all stock and needs to be "freshened up" to say the least. I was thinking about replacing the bushings and adding a nice powder coat to these arms, rather than spend another $500-$600 for new ones. However, if different arms will greatly improve traction and help reduce "burn outs" then this may be an option. Again, I have very little knowledge in this area and your options are greatly appreciated.
Also, I will be installing "drag bags" in the coil springs when I do whatever it is I am going to do with the trailing arms. One thing that is especially important is that I do not change the stance of the car.
