Help New HVLP whats this screw do???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2005, 07:52 AM
Ratchet's Avatar
Last journal entry: Ontario Camaro Nationals 2008
I have always used a standard high pressure cup gun in the past and recently I purchased a HVLP gravity feed gun. I have sprayed primer with this gun so far and it worked great but I am not sure if I am adjusting it properly.
The Gun is a G.R.I.P. product and it seems to have an extra adjusting screw on it that I don't know what to do with. First of all the basics. The gun has a standard set up for material flow where you turn the screw in and out and that adjusts how much material flows through the tip. It also has a dial on the side which is quite nice to adjust the width of the fan. It has an air pressure regulator attached to the bottom of the handle that you can adjust the pressure that goes into the gun. BUT it also has a small adjusting screw right beside the air supply fitting that I don't understand the purpose of.
If you adjust this screw in all the way it will shut the air supply to the gun right down. So thus far I have had it wide open and adjusted the air supply to the gun with the regulator. What is this thing for??
Ric
Old 04-17-2005, 10:41 AM
I believe that screw adjusts the pressure of the air coming out of the gun. I have one on one of my guns as well. I just turned it until I had full pressure and went on with the spraying.
Old 04-17-2005, 10:46 AM
The only use I could see for this is if you used a special test cap with air pressure guage. You would have no regulator (to rob CFM) and adjust that knob to get the desired pressure at the cap. You would then remove that cap, reinstall the regular cap and go about painting.
Old 04-17-2005, 12:33 PM
Had one of those screw's on my IWATA gun that I purchased while station in Japan(early 80's). I would set the pressure at the requlator, allow for pressure drop at gun....Then I would use the screw to make small final pressure adjustments based on my test shots. Not an expert here, but the ole educate...then trial and error type....but it worked for me.
Blaster
Old 04-17-2005, 12:40 PM
Ratchet's Avatar
Yeah I was thinking it might be for fine adjustments too. But that would be a major pain if you had to change caps each time to check the pressure. Is it possible that it would interact with the requlator on the inlet of the gun???
Ric
Old 04-17-2005, 12:58 PM
I never changed any cap's. (remember I am a self taught trial by error type)I always shoot a test pattern, based on that test shot I will make adjustments to the SCREW, requlator output pressure,or fluid as required. I do feel the the SCREW is for making slight pressure adjustment at the gun. ie If the pattern makes me think there is to air pressure, I would use the screw to dial down the pressure(how much psi I don't know), I let the test pattern tell me. Hope this helps....Blaster
Old 04-17-2005, 07:55 PM
That's just a built in regulator, some of my guns have them as well. I use my larger guns with the valve screw wide open and use a guaged regulator at the air inlet. On my detail guns I use the built in regulator screw and attach the line directly to the gun-provides a little more mobility on these smaller guns without a guaged regulator attached to the handle. Bob
Old 04-17-2005, 08:04 PM
Ratchet's Avatar
Thanks Guys
So I will leave it dialed all the way out and use the regulator atached to the inlet on the gun to regulate the air pressure.
Thanks Again
Ric
Ric
Old 04-17-2005, 08:21 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
You got it. Run it wide open.
They are more of a PIA that anything,especially if it turns easy and you accidentally "adjust" it while in the heat of battle.
I use mine on the big gun's to reduce the air volume down when shooting small spot's/parts during a session. That way I don't have to grab the touch up gun and continue on with the project.
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 5 11-07-2011 07:14 AM
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
Supercharge it! The replacement for displacement... Roots, Twin Screw, Centrifugal? MadJester Engine 19 12-12-2004 03:20 PM
