Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help a noob, welding
Old 10-06-2005, 11:43 AM
35WINDOW's Avatar
35WINDOW 35WINDOW is offline
Last journal entry: Update on my Build-Lights
What I do is use a Roper Whitney punch and make some small plugs-then I carefully drill the hole to the right size and weld the plugs in-if you are careful with your Welding, you can put less heat into the Door panel (less warping), then Hammer and Dolly the area back to normal (stretching)-by the way, where in Colorado are you?
Craig
