-   -   Help a noob, welding (http://www.hotrodders.com/forum/help-noob-welding-71511.html)
a69446b 10-06-2005 07:47 AM
1 Attachment(s)
OK
I've got no experiance welding ( but I did sleep at a Holliday Inn last night :P ) I've done the rest of my car and I want to tackle this.
The project is to eliminate the holes for the chrome trim on a door. I have a small O/A welder that I have a basic understanding of, I have a spare door I can practice on. What's the best way to do this, fill in the holes with weld material, cut out a small piece and weld it in.
How do I keep from warping the door
Thanks Bert
furrystump 10-06-2005 11:33 AM
If the holes aren't very big you can just place a copper strip over the back of the hole and fill with your welder. Short bursts. The copper supports the bead and acts as a heat sink. :welcome:
35WINDOW 10-06-2005 11:43 AM
What I do is use a Roper Whitney punch and make some small plugs-then I carefully drill the hole to the right size and weld the plugs in-if you are careful with your Welding, you can put less heat into the Door panel (less warping), then Hammer and Dolly the area back to normal (stretching)-by the way, where in Colorado are you?
Craig
a69446b 10-06-2005 03:26 PM
I'm in Denver west side
firebird_red 10-06-2005 06:16 PM
A copper backing plate and a mig welder might give you less warp to fix.
