If the holes aren't very big you can just place a copper strip over the back of the hole and fill with your welder. Short bursts. The copper supports the bead and acts as a heat sink.
What I do is use a Roper Whitney punch and make some small plugs-then I carefully drill the hole to the right size and weld the plugs in-if you are careful with your Welding, you can put less heat into the Door panel (less warping), then Hammer and Dolly the area back to normal (stretching)-by the way, where in Colorado are you?
Craig Last edited by 35WINDOW; 10-06-2005 at 11:51 AM. |
A copper backing plate and a mig welder might give you less warp to fix.
| Welding info | Kevin45 | Body - Exterior | 10 | 08-26-2011 08:09 AM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| welder reccomendations? | rally4x4racer | Garage - Tools | 32 | 10-14-2008 09:00 PM |
| Question on Mig Welding - HOW to | modas | Body - Exterior | 43 | 12-31-2005 09:48 PM |
| Welding Books | Magnus_Jager | General Rodding Tech | 6 | 11-29-2005 03:57 PM |
