As the saying goes, there is no replacement for displacement. This means bigger cubes. Gas mileage is primarily affected by lead in foot (like me). If you use a small carb like a 600cfm vac sec Holley, you will be able to get good mileage.
3.08 is prob what the rear is. You can get close by jacking rear end up in the air, spin the drivers side rear tire one revolution and count the rotations of the driveshaft. This will help determine if you have 2.73 or 3.08s. Also, you wont realize much torque with a pg and 3.08s. A th350 trans will significantly change the way it takes off. My 68 camaro had a pg with a 327. It's best ET was a 14.70. After I switched to a th350, it was running 14.00 ETs. Quite a difference. And that was with a 2800 stall in the PG and the th350. By the way, the torque converters for a stock PG and a stock th350 do not interchange. It will assemble fine, but it will not work....
Also, that 250's cylinder head may be of value to guys with older boats with a straight six. I had a guy begging me for the one I had a long time ago. So, ask around before you dump the engine.
CAD
